I am learning a new language. I use Google translate voice recognition to improve my pronunciation. To increase the sensitivity of my iPad 8 generation microphone shall I use Bluetooth microphone. It’s available in Amazon from price starting at Rs. 400.
hi bro, Yes you can use any bluetooth mic or wired mic setup to let iPad receive good audio with less background noise. go with some good quality mics with decent reviews. JBL or any branded mics will be good buy.
Thank you very much Robin. Shall I go for Jb super from Amazon. It has got a good review and costs only Rs. 499.
Sure bro. good reviews for mic too? then yes go for it. check return and replacement options too. that will help.
Thank you very much for your immediate reply.
