Budget Monitor for office use
Hi bro ,
How are you ?
Bro , enoda msi lap la screen la line varuthu bro , sometimes iruku and sometime iruka maatuthu bro . So looking for an budget monitor that suits for mac and windows .
Future la mac ku shift aagiruvan bro !
Monitor suggest panuga bro for using mac and windows . ( budget under 9k )
I am good bro, thank you. hoping you too. Do check with LG monitor bro. I am using LG 4K USB C monitor which comes around 36K budget range. its cheaper to connect with mac computers. There is also 2K monitor, but they are crossing your budget.
https://amzn.to/4crYFdW
My suggestion is to check in LG brand or in Dell to find something that fits your budget. once check with local computer sales shop too. most of them have budget segment monitors under 10,000 range.
Okay bro . Check panra bro local um , enga oora Suthi dell and Lenovo showroom tha bro iruku .anga Ketu paakura …
Na link share panra , antha monitor epd iruku nu soluga bro …
https://amzn.in/d/0f2QtoJb
Intha monitor ku usb c to hdmi converter vaagita mac lap um set aagum la intha monitor ku … ( this is for future purpose not now )
ok bro, nalla reviews irukunga neenga link la share panniruntha MSI monitor ku. ithuvum consider pannalaam. but entha monitor choose pannaalum direct USB C irukara mathiri ponga. converter or adapter use pannuna quality loss irukum. refresh rate full a irukaathu. direct laptop to monitor ore cable use pannunga. thats always good.
Okay robin bro :+1:t2:sure :handshake:t2: …!
Na check panra bro usb c monitors
Thanks bro🀝🏻
Its double your budget, but its one of the best monitor for Macbook I recently come across bro. do check user reviews and decide accordingly.
Okay bro .
I will check
Thanks bro :handshake:t2::heart:
Hello,
I am agree with your answer.
