Bug in WhatsApp and Gboard
Bro android la Whatsapp la add account feature iruku aana iPhone la ulla whatsapp la andhe feature inum varala
Aprm iPhone heat aaguna slight a oru 5 sec kita lag aagudhu
Bro aprm gboard la tamil la type pana android la Vara maadri iPhone la uyirmei eluthukal olunga varamaatuku
Inthe prblms a check Pani report panunga pls bro
hi bro, iPhone ku whatsapp innum antha option kondu varalainga. may be future la varalaam bro. by any chance low power use pannureengala? becase heating appo issue aaga koodathunu system performance reduce aagum. few minutes temperature reduce anathum again normal la work aagumnga. low power mode on la irunthu off pannitu check pannunga.
Gboard app recent years a update pannave illainga. google gboard app la namma already few bugs irukunu videos la cover pannirukom. even though google ku notify panniyum ippo varaikum update or fix pannama thaan irukaanga.
default iOS 18 tamil keyboard try pannuneengala? ippo tamil transliteration or tanglish typing nallave work aguthunga.
Mm ok bro
Aama bro Naa low power mode la vachen because battery Konja high a kidaikudhu Naa Konja cool environment la low power on Pannu brightness oru 20% vachi and volume 50% vachi fulla YouTube paathen enaku 8hrs 7mins vandhuchi adhula Naa low power mode on panen
Aama bro apple keyboard la nalla varudhu
Also enoda ipad inum 17.5.1 la tha iruku personal hotspot connect panuna ipad la internet laa use aagudhu but software update matu pana mudiyala bro
battery backup important appadina neenga adjust pannanumnga. because low power mode la screen refresh rate and performance reduce aagum. so features compromise pannuna battery backup athigam bro.
wifi la thaan update work aagumnga. hotspot la update aagathunga bro.
