Hi bro… is it worth to buy a new iphone 14 pro max for 1,10k now ?
hello bro, depending on storage the price of 1 lac 10K can be justified. but yes its good to buy 14 pro max models right now. It has best spec and suitable for next few years usage without issues. Is it 256GB model or 128GB model?
Its 128gb model bro !
ok bro, if there is any negotiation possible try to bring it below 1 lac segment. like 95K would be good buy right now for 128GB model. if its 256GB then slightly above 1 lac will be good. just my opinion. look for trusted shops and sellers.
