Hi bro iam planning to buy 15plus from US for my father. Is it worth buying it cost around 60k 15 plus 128 gb. Do warrenty covered in India when we purchase from US
Yes bro. usually pro models are in less price when we buy outside india. But if you are seeing good price difference with 15 and 15 plus then its good to consider from USA or UAE region. you can use it in india and warranty also covered.
If the discounts are good, then you may consider getting applecare+ to protect your device for 2 years. only if budget allows. otherwise it shouldnt be a problem.
Bro US LA purchase Panna box oodha kondu vara mudiyaada. Without box tan kondu vara mudiyumaa
Kondu varalaamnga bro. carry pannitu varavanga just one open box unit baggage la kondu varalaam. kaila avanga use pannura phone normal la vachirukalaam. no problem bro. multiple phones varumbothu question raise aagumnga customs la.
