Bro na 2 days la iPhone 16 pro 256 gb vangalam nu Irukan . This is the first time I am purchasing a iPhone ! So na check pannitu irukum pothu ! Supreme mobiles trichy la
1,16,500 but Iplanet la 1,30,000 !
Which is the best to buy ! Around 15000 difference varuthu
Hi bro, third party sellers kitayum vaangalaamnga no problem. offers price nu stores la different price iruka chance irukunga. enga best price iruko verify pannitu vangunga. Also indian unit or imported unit a nu check pannikonga. normal la imported models price kammiya kedaikumnga.
Indian unit vangureenga na Protect+ mathiri iPlanet la neenga apply pannikalaam. just to get 1 year damage and full warranty coverage. irukara discount la antha mathiri buy pannikalaam. not mandatory, just a suggestion.
other than that, price enga best o pathutu vangunga.
Hmm okay bro ! Can I ask few more questions!?
I think it’s safe to buy with warranty ! How to check Indian unit and imported unit !?
I am. Medical,student so I am going to use this phone for next 3 to 4 years !? 256 gb is enough !?
Sure bro. you can ask as many questions you want before making the purchase. Will try my best to assist.
Safe to buy with warranty always. The model number ends with 1 or 2 digits that let us identify the country whether india or other country.
For example if its india then the model number ends at HN.
You can see the complete list here in this article,
Mostly sellers inform before selling imported units. Just personally you can do this check too.
Storage selection depends on how much content you are going to store on device bro. for more photos, videos and files 256GB is good choice.
But make sure to backup important sensitive files always to Google Drive or iCloud to avoid any data loss. Electronics can fail sometimes and we should not end up loosing the data. so to avoid such issues taking backup periodically like few months once will prevent data loss.
Thanks bro ! U really helped me ! I will check it once I get into the store !
Along with iPhone I am going to buy AirPods ! I don’t want to buy AirPods in third party website so I am planning to buy through iplanet !
Which AirPods is best now AirPods 4 anc or AirPods Pro 2 with Apple Care ?
Good to know bro. thats always safe to buy airpods from authorised sellers bro. check for offers too. and it is must to get applecare+ for airpods as said in our videos.
Only if you dont find in-ear type comfortable to use go with airpods 4 with ANC bro. otherwise go with airpods pro 2nd generation. it brings rich bass and better comfort when people can use in-ear type headsets.
Thanks bro
! Last question ![]()
- I brought a new iPad Air m2 in July 2024 and created a temporary Apple ID in my iPad ! Like I want to delete it and create a new one ? How can I delete that Apple ID ?
- If I create a new Apple ID once I get my new iPhone ! Can I use the same Apple ID in both iPhone and iPad or should I want to create separate Apple ID for iPad and iPhone ?
Welcome bro.
We can delete apple id by logging into our apple id at https://privacy.apple.com/
important thing is, we can only create maximum 3 apple ids on a device bro. So even if you delete an apple id, your device still have only 2 more apple id creating limit. after that only existing apple id can be used bro. so think twice before deleting an already created apple id and creating another one on the iPad. -
Using one apple id for iPhone and iPad will be good idea bro. to sync data, use all the apple ecosystem features seamlessly between your devices.
Thanks bro ! Tmrw I will buy AirPods Pro 2 and Friday I will buy IPhone !
Thanks for ur helpful tips
