I thought of buying this in India bro but all are saying it to buy in uae or us … because it have good quality of warranty… while my q is Apple has universal warranty Thana bro India model na etha prachana ah bro
Hi bro, there is no problem in Buying macbook from USA or UAE region. you can also get applecare+ to get 3 years complete coverage even for damages we do. its optional but if you need that extended coverage for all damages being it as expensive macbook purchase. the same applecare+ can also be purchased from USA or in India within 60 days from the date of purchase.
Can u suggest temper screen cover for m3 pro 14inch and case and keyboard cover slip for this model bro
Application process is bit difficult for macbook displays bro. if you have previous experience you may try it. else apply it with the help of any mobile shop service person help.
It is not recommended to wear both screen protector and keyboard slip. As it could increase the gap and affect macbook lid properly closing with its magnetic lock.
We have to choose between one.
Thank you bro ![]()
