Call Failed Error for past 10 days on iPhone
Hi Bro past 10 days whenever I make a call two ring goes and then cuts and it shows call failed what to do bro
Hi bro, as said in our recent video about iPhone Call Failed problem, this issue seems to be network specific issue. Are you using physical sim or eSIM?
Physical sim bro
Ok bro. if its 2 years + older sim card try changing the sim card to new one by visiting the network showroom. if its new physical sim, then report the issue to network support. they will take 1 week time normally to address this issue in your area.
Ok bro I will get new SIM card and try
