Hi Robin bro. I’m using iPhone 13. Updated to iOs 18.2.1. Imagine I’m on a call & receiving another call. Andha 2nd call varumbodhu, full screen la change aagi, it’s showing just 3 options - 1.End & Accept. 2.Decline 3. Hold & Accept. Instead, I need this 2nd call to be shown above ( Banner ). Kindly help me with this. ( How to Change waiting call Interface? )
hi bro, you can change the incoming call banner style by going to settings - apps - phone - incoming calls - banner. here after it wont show in full screen.
Already Banner option is ticked bro
then it shouldnt show full screen during calls bro. only if we tap on the banner at the top it will show full screen. otherwise incoming calls will be displayed as banner at the top inside dynamic island.
You can perform “settings - general - reset - reset all settings” once and then check if the banner option correctly working or not.
Bro. Dynamic island? I’m using iPhone 13. So work aagadha?
When unlocked, 1st call indha maadhiri banner paaka mudiyidhu bro. But when ongoing call, call waiting la irukumbodhu, banner la paaka mudiyala
got it bro. this could be due to the active call which apple might have forgot to force the banner feature. made it the way it automatically showing in full screen as a call is already active and we can decide whether to merge the call or decline with other options.
We may submit a feedback to apple and see if its changed or not. but again, if this is how apple want the feature to work they may not change it. but its good to submit a feedback once.
Bro. Indha issue’a oru sentence ah form panna teriyaama dhan unga kitta keten. Konjam enakaga indha favour pannunga. Neengale oru sentence form panni sollunga. Neengalum adha feedback laApple ku send pannunga. Nanum send panren
Already submitted feedback bro. mentioned as “within settings - apps - phone - incoming calls - banner” option selected on my iPhone 13. Still it is showing full screen incoming caller screen when I receive second call. the banner feature works for first call, but not when I receive second call with call waiting option enabled. kindly fix it.
Thanks a lot bro. I will report now
