Hi bro, we can adjust the exposure settings while taking photo to reduce the amount of flares you are seeing. next taking direct light source photos, we do see some flares. that is normal. if its too much then we have to adjust the angle to reduce the flares. direct light source in night time creates reflections inside the camera lens the way its designed. thats the main reason.
Oke Bro. This is the screenshot of video taken. Will check as you mentioned. Thanks for your Suggestion brother.
