Bro iphone 15 plus ku camera protector podalama but andha ring type pota image quality break aaguma…
Beacause camera round side la black pogudhu any solutions
some lens protectors normal la work aaguthunga. but finding the good lens protector is the tough part. amazon la reviews paarunga. if you see any good review ones try them under 500 rs budget range.
Lens flares athigama iruntha mattum remove pannunga. otherwise continue using it bro.
As I suggest in our videos, camera section la protection irukara mathiri cases wear pannurathu protect pannumnga. to prevent direct exposure to camera lens metal surface.
Robin bro video link for camera protection?
I havent recommended any lens protector so far bro. intha amazon product try pannunga.
Nandri bro
