Guys please answer this… Will it be comfortable to use macbook air m2… For studying bca and mca ??
I am gonna buy one tho…
Like what is the main thing that Misses in Macbook from windows???
hi bro, absolutely yes. Macbook Air m1 or m2 both will be good choice. consider getting 512GB if budget allows for long term usage.
If you dont have any windows apps requirement then macOS will be best to use it every day. do check follow mac basics episode. that will help you to start with macOS.
let me know if there is any further questions.
okay mr pro… ur tips are really addictive tho… i bought macbook air m2(256), thats enough tho and some accessories, thanks anna, thanks a lot , fan from chennai…keep growing, will support to the fullest.
Welcome bro. will keep doing my best. Congrats on your new Macbook Air by the way.
Create Question topics here if you have any questions in future. Have a productive day.
Hi , I think 256gb ssd is not enough long term use ( because of software are producing so much amount of catch , even iam using catch M1 256gb for software development ) buy external ssd like Samsung t7 which is useful
Yea dude… but I’m okay with this actually… bcs for my laptop no games and no movies and only small pdfs…
Thank you for this concern
