Can I buy MacBook Pro 15 inch for programming?
Hello bro , how are you , hope you are good . I have some confusion on buying MacBook, Iam a student , for programming and some entertainment purpose I need an Mac , but I prefer a big Display like 15 inch , MacBook Pro 2019 i9 2.3ghz with 16gb ram , is good to buy it ?? I checked a serial number on apple website
Please see the photo I have attached, it showing the model and year but purchase date is invalid , I asked the dealer ,he said it is a demo Mac so purchase date won’t come he told to me , now can I buy this for 95 k
My need is for programming and some entertainment purpose like watching movies and YouTube , is it good to buy and will come for another 2 to 3 years please clarify my doubts Sir :heart:
Hi Ajay, I am good. thank you. how about you? Many programmers and normal users still use Intel processor macbook pro models. Especially, after 2015 apple started providing good SSD speeds which makes is still very well usable for every day works. M1 series processor models are good to consider if you are planning to use the machine for even longer periods.
When we buy something closer to 1 lac budget, its good to get it with a warranty unless its recently warranty expired and have good custom spec model is what I would suggest.
This 2019 model will definitely work well for next 3 to 4 years. Pricing could be around 75K which will be reasonable. Sellers decide pricing according to their purchase price and profit margin.
You have to decide based on the price you are spending and what are all the alternative options available in the market right now.
Go with Intel processor models only if the apps you are planning to use as a programmer requires intel processor compatibility reasons bro. else considering M1 or M2 models will be good idea.
Okay bro ,thanks for the information you given now . I have a choice on MacBook Pro m1 13 inch , but if a wanna buy i9 Mac it will come for another four years for my moderate usage ? This is my only confusion Iam struggling , yes or no ?
i9 macbook will definitely work well bro. as it also has good SSD speeds and RAM capacity. you can choose when you see good pricing offers.
