can I replace the battery for ipad ( I reffered to the iplanet salem they said that battery can’t be replaced ) . if then suggest me the third party service center.
Sadly, we cannot replace the battery of iPads bro. Replacing entire iPad is the only option apple service center has.
You may check with third party service center like iPlace, Coimbatore to know the possibility and get it done. If you are ok with it.
