The power adapter that comes with MBP 2021 16" is big and does not fit in my desk. Can I use any PD charger to charge it? Is there any minimum wattage rating needed for 16" MBP 2021?
I use the MBP always connected to power as I use only the external monitor (mirrored mode) as the main and only screen. Will this cause any battery issues in future?
Yes bro. You can use any branded adapters with the provided usb c to usb c cable. Wont be an issue.
And yes either in extended monitor setup or in clamshell mode you can use. Power will be auto cut off and managed automatically.
Thank you!
