Hi…I’m planning to buy iphone 17pro only esim version from USA and use it in India.Will there be any issues regarding the esim? Does the Iphone 17pro only esim version purchased in usa is compatible in India?
hi bro, no issues already 16 models use pannitu irukaanga india la. esim supported networks use pannikalaamnga. so yes you can buy from USA.
