Can’t connect my iPhone hotspot with my android phone
I’m using iPhone 13 with ios 17.3, before that I used iPhone 11. I’m having second android phone which moto g40 fusion. Before 3 month my iPhone 11 hotspot was not connecting to android phone, I tried resetting iPhone and that android also. Actually, it show that “IP configuration failed”. I thought that iPhone 11 is problem then I changed my iPhone to iPhone 13. But the problem continued.
Not only me, I seen this problem in internet also
How to solve this problem
Hi bro, there is a bug related to hotspot with iOS which is preventing other devices from connecting immediately. I have tried and after few times it connected. But its a known problem. Have submitted feedback to apple and waiting for an update to fix this issue.
For now, you can try setting up simple password and attempt connecting to iPhone hotspot again.
Were you able to connect your iPhone to Android device hotspot?
I tried connecting iPhone hotspot in android several times
I’m already using simple password
My hotspot password is 123456789
I tried full reset in both mobile
How to inform this issue to Apple
Forgot to include the link bro. here it is.
I have also sent a feedback. expecting a fix soon bro.
Reported successfully
select maximize connection turned on in personal hotspot menu
