Hiii… I am using 200gb iCloud storage. I want to cancel it. How to do it? and what happens when I cancel the subscription?
Hello bro, if there is no sufficient funds added to our apple id it wont renew next month. also we can cancel icloud subscription anytime by navigating inside settings - your profile - icloud settings.
Once cancelled you wont be able to upload new data. Existing data will stay on the cloud and you will start to see icloud renewal notification regularly on your iPhone using the same apple id.
This will also prevent uploading new contacts you are adding to your contacts app, notes app data and other apps related data. So downloading any data stored on icloud to local computer and freeing up the space will be good choice bro. if you are not planning to continue using icloud paid plan.
