Cant able to connect iPhone to macbook
Hi bro
Hope you’r doing well…!!!
Still that storage issue is there bro before ios 17 which is in IOS 16 la if I use insta or YouTube in Phone storage option la it used to be same no difference will come bro but after IOS 17 endha app use panalam adhu storage la show augudhu bro every time uninstall panni again install panara mari iruku bro any solution for this bro
Before using this is the image of that bro
After tht this is the image bro
Edhuku Enna dhan bro panaradhu
I am good bro. Thank you. Hoping you too. At present 1 or 2GB increase is problem bro. But dont worry. Free storage evlo iruku nu paarunga. Intha double storage or increase agurathu upcoming updates and optimisation la fix aagumnga. Instagram and other apps are working on updates to make it well optimised for iOS 17 device.
So upcoming updates la improvement irukumnga. dont delete and reinstall the app frequently.
Just let it reach around 4 or 5GB in size then you may reinstall bro. it takes time to reach that size.
Hoping updates from app developers reach us soon.
I’m literally regretting on this update bro but after seeing ur messages it gives hope and it makes happy bro anyway thnks for this information bro let wait for upcoming updates :wink::wink:
Other than this storage bug, overall do you see any improvement with 17.1 bro? my suggestion is kindly to use it for atleast 3 to 4 days and see how it works for everyday usage. then it will give good idea.
Yes bro Battery performance looks good thn before like yesterday evening at 4 till 100 I kept charge nd over night the graph was same and now time is 7:12 battery percentage is 28 from my point of view is seem good and I’m is IPhone 13 bro vara endha difference therila bro need to check vana check panitu update panaran bro
Sure bro. Good to know.
Hi bro hope you’re doing good…!!!
Eappo bro endha storage issue fix augum i thought this 17.1.1 lo thy will fix it but in this also thy didn’t bro phone app also consuming more storage bro if insta na ok bzz we can uninstall and install it again but for phone app we can’t do like that bro :cry::cry:
Hello bro, I am good thank you. hoping you too. can you try to use it continuously and see whether it crosses 5GB+ storage over upcoming days. This cache improvement on apps like video streaming has to be fixed from their side bro. for example if we use netflix or prime, then without downloading the movie to our local storage, it is not possible to stream them as you know.
So that sort of cache improvement for played content has to be done from the app developers. as reports receive they do work on it and improve over the updates.
Is the device storage getting full because of this or affecting your total free storage limit by any chance?
Yaa bro storage is getting full if it reaches 5gb im uninstalling it and installing bro thn storage is much better anyways waiting for the better improvements for upcoming updates…:wink::wink:
lets see bro. will definitely update in our channel as soon a bug fix specific to this apps arrived. will be monitoring.
Hi bro how to block spam messages on iPhone bro is there any option if yes can you please suggest it bro…
hello bro, we have to use third party apps like SMS Spam Stopper or Truecaller SMS Filtering service.
Hi Bro,
Hope Doing Good…!!!
After the update of 17.2 Still that storage issues exist bro I thought on this update this will fix but not😢 whether I’m only facing this issue or not I’m not getting bro, is this issue have you noticed on ur phone bro….??? Or any one has noticed on this issue……
Hello Bro, I too check every time we receive an update. Instagram still consumed 5.5 GB around space and no improvement at all. but mine is around 5.5 GB space for quite sometime and not increasing or decreasing.
Is the storage bothering you with free storage space in your iPhone? any problem in storing photos, videos or other files?
Hello bro,
Ok bro 5gb varavariki use panaran bro and one more information mobile vangi 11months 9 days augudhu battery percentage 90% is it fine bro…?
for 11 months 90% is normal bro. dont worry. charging practice follow pannureengala? charging whenever it reaches around 20%?
Thnk bro I was following ur suggestions on video bro.
Then dont worry bro. 1% a month on an average is normal. some months it wont reduce. continue using it the way you want and overall we will see that 2.5 years average mark.
