capes india and spigen fitting??
bro does capes india iphone 16 pro max armor mag safe clear case and spigen tempered glass fit properly without any issue or spigen tempered glass will lift when capes india case is used please tell bro!!!
Capes India cases mostly fit with all brand tempered glass bro. is the tempered glass with frame type or without frame just just the glass piece?
It is not possible to tell in advance. we have to see the case type and tempered once in person to decide bro.
spigen ez fit tempered glass-16 pro max without black border and no cut out for dynamic island
Cases designed in a way to fit most commonly available tempered glasses bro. as the tempered glass dont have additional black border frame, it should work. try it and see.
ok bro now i am moving forward to order now because as yu mentioned there will be no issue in fit
Processing: IMG_9425.jpeg…
Processing: IMG_9424.jpeg…
bro both capes india case and spigen fitting completely perfect no issues
Good to know bro.
