Charger for iPhone 15 pro max
Hi bro , I am currently using Samsung original 25W charger to charge my iPhone . Charged only two times so far, I feel phone getting warm while charging is it normal.
Should I continue with the Samsung 25W PD charger ?
If you were to suggest a good charger in budget for iPhone 15 pro max what would it be?
hello bro, during fast charging heating is normal. but it wont be too much heating or we dont see temperature warning. you may continue using it and if you have any doubt, consider getting 20W apple adapter. otherwise use samsung adapter for 2 weeks and if heating is too much then consider charging bro.
Hi Bro, Just an update to the above issue, I have purchased stuffcool 20W charger and I could literally feel the difference, less heating during charging. Thanks for the info brother
Good to know bro. Kindly share the link if possible.
Hi Bro,
This is the stuff cool charger I bought
https://amzn.in/d/4ggpL59
Cost is 600.
Potronics , Vaku , Ambrane were around the same range.
I chose this one bcos it was rated highly by Fonearena YouTube channel
Stuffcool also good choice bro. you can continue using it. no problem in that.
Bro, what is the maximum watts charger we can use for iphone 15 pro max?
accepted input power is 27W as last time I have checked bro. so 20W is the sweet spot to use with which also does fast charging to the device. else you may use 30W adapter.
Okay bro.
Thanks
