Charging practice of iPhone
Hii broo Iam vignesh here so i have purchased iphone 13 last week
Does charging iPhone above 90 percent everyday is bad or can reduce battery performance?
Mostly people say that keep your phone between 40 & 80% and don’t charge it more than 90%, is this true?
what’s the best way to get most from the battery and keep it running good?
hello bro, its not like that. optimised charging feature will take care of charging above 80% based on your usage. so keep that toggle ON and continue using the phone normally. As I suggested in our battery health maintenance tips video, you can charge the device when it reaches around 20% and avoid frequent drain. thats all needed.
Okay broo done
Why iam asking is because while purchasing in store they told to maintain until 80 only while charging or else the battery cycle will be affected it seems broo
Is that true??
yes bro. charging 100% all the time may reduce battery health. but the important thing is, how you are using the phone. if your usage is normal and you charge once a day it wont make big difference is what I understood. if your usage is heavy then battery health will reduce bit faster.
Okay broo I understand
Thank you broo
