Bro, I’m facing that charging was hold due to iPhone temperature. How to fix this?
hi bro, this could be a temporary bug if you are getting this message without the phone heats up during charging. where iPhone cut off automatically to reduce temperature and then charging continues.
you can continue charging ignoring the warning. it will automatically adjust.
Same issue enoda 12 pro max layum phone cool ah iruntalum same warning varutu bro ios restore panni patidan still same issue eatum workaround irunta suggest pannunka
could be iOS bug bro. but it wont affect charging. just continue charging and we can see the fix in upcoming updates.
