Bro, recent ah system storage 30gb past poitrunthuthu bro all tips of your try pannen , year change panna bothu temporary ah kammiaaagi then thiruppi rise aagiduchi to same level, then i tried to off load all apps i had installed on iPhone, which did clear all the system data i had to normal 5-6gb , i kindly request you to add this tip on your videos enagala mathiri nanbargalukku uthaviya irukkum , thank you bro
Hello bro; I did mention that it will climb to a certain level based on the apps we use. But force closing apps will again take more battery power when we reopen the same apps. I will see if anything can be done to preserve that storage space.
Thanks for your inputs
