Confusion on choosing iphone 14 plus vs iphone 15 plus
Hi all
what is the difference for the battery in 15 and 15 plus ?
Is the difference really that big
is that advisable to go for 14plus instead of 15plus because of financial constrains
Is there any notable difference in battery usage time in 14plus to 15plus
pls do reply guyz planning to buy today
Thank you
hi bro, as per apple website its the same battery lifetime of 26 hours video playback in wifi when streamed. which means we will not see big difference in battery performance.
plus models are good and based on our usage battery backup will vary. overall we may see maximum 1 hour around difference while comparing between 14 plus vs 15 plus according to our real world usage.
if budget allows go with 15 plus, otherwise 14 plus model will be good choice bro. just to not miss USB C, brighter display and dynamic island feature I am suggesting 15 plus.
