Connectivity issue in Iphone 14 pro max
Hi, I bought a new 14 pro max last week. I’m more than 10+ year Android user switching to iphone now. Since I’m facing many issues.
  1. Mobile data stopped working for unknown reasons
    ( When I’m playing games or using Whatsapp with mobile data suddenly it starting to getting buffer. Mobile data icon keep showing 4G but nothing works. Airplane mode will fix the problem few times but not all times. Otherwise I should need to restart my phone to get back to normal )
  2. Wi-Fi & Hotspot Connectivity issue
    ( In my collage I connected my friend’s laptop [Its more than 5 yrs old Dell laptop] with lan cable for internet. After that I opened mobile hotspot in his laptop and connected my iphone. It’s worked perfect. After that I connected that lan cable to my M2 Macbook air & opened hotspot. This time my phone connected with my MacBook but hotspot not working properly. And some other mobile hotspots [Eg- A53 5G] not working for my phone)
  3. Whatsapp status missing issue
    (Thank you. I already got the answer for this from this site)
hello bro, congrats on your new iPhone, I hope you have experienced iOS once before making the switch. Your phone is under warranty, so dont worry. for any defects it can be claimed at apple service center. Let me suggest some troubleshooting steps to fix the issues you are experiencing.
  1. Are you using Physical SIM? If yes, then consider getting the SIM replaced at mobile network showroom. This happens when we use older SIM cards. If possible you can move to eSIM and that will help fixing the problem. also go to settings - mobile data - mobile data options and set only 5G or Only LTE mode while using the data. Right now, with most networks 5G being unstable, due to network switch all of us are experiencing sudden data disconnection and call disconnect problems.
  2. for personal hotspot not working, you can try this troubleshooting method to get it fixed.
  1. WhatsApp Status not showing for most of our contacts and friends is because of whatsapp latest update problem. expecting an update from whatsapp soon to fix the problem bro.
Let me know if you have any further questions. you can always create a new topic. Have a great day.
Thank you so much for your speedy replies and explanations bro.
But Q2 la naan kedathu iphone internet ai hotspot la mac or other mobile ku share pannum pothu issue illa. Vera mobile or laptops la irunthu ennoda iphone ku hotspot connect pannum pothu connectivity issues varuthu.
Na already network settings ellam reset panni paathen. but its not fixing my issue bro.
Welcome bro. Hotspot namaku connect panna mudiyalaina, mostly hotspot initiate pannirukara device a restart pannuna fix aagalaamnga. it did work for me with an android hotspot connection once. give it a try and see bro.
