Hi bro. Contact Posters yepdi work pannudhu? If I save a picture to one of my contacts, it’ll display when that person calls me. If I don’t save his picture & if he uses an Iphone 14 & Contacts app la “My Card” section la avaroda picture save panitu, ‘Contacts Only’ option select panitu, then ennoda number call pannumbodhu, enaku show pannaadhaa? If it does not show, apo yedhuku ‘Contacts Only’ option iruku? Do clarify this bro
Hello bro, you are correct. namma friend contact save pannirukom appadina, avaru set pannirukara contact poster auto sync aagumnga. otherwise namma set pannura contact poster display pannumnga. so we can choose contacts ku mattum sync aaganuma or always ask privacy setting vaikalaamnga.
Ennoda friend avaroda picture “My Card” la set panirukaaru. With ‘Contacts Only’ option selected.
I’ve saved his num in my mobile without a picture or a contact poster.
He calls me. But ennoda mobile la avaroda picture or contact poster display aagala.
What should I do to make his picture display in my mobile?
Do clarify this bro
Sure bro. make sure both devices are running latest iOS version. because some bugs getting fixed with each update. sync agurathula issue irunthalum fix agirukumnga. let me know if both devices are updated.
Bro. Both devices are updated to latest iOS 17.2.1. Still Contact posters are not displaying. What should we do now?
Kindly share the contact posters you have set here bro. take a screenshot in your iPhone where you have setup contact poster. hide phone number if its visible for privacy reasons. if possible get the contact poster set by your friend and share it here. I will compare and check whether any fix can be found.
under settings app - contacts - share name and photo - name & photo sharing is enabled bro?
It is enabled in both the devices bro
One last question bro, contacts ellame icloud sync la irukungala? or google contacts use pannureengala bro?
Happy New Year 2024 Robin bro
Sync panala nenaikuren bro. If you can answer this, answer here or else idhu pathi oru shorts podunga bro. Contacts mattum iCloud la sync panra maadhiri edhaavadhu panna mudiyuma? Coz Whatsapp backup 4 Gb mela iruku. Photos & Videos 3 Gb mela iruku. So idhellam iCloud la sync panna space ila. So Only Contacts save panna edhaavadhu option iruka bro?
Happy new year bro
Yes we can sync only contacts.
Go to Settings - your profile - iCloud - Show All - Contacts toggle ON panidunga. wait for few hours to let contacts sync to your cloud account.
I think ithu thaan issue va irukalaamnga. kandippa ungaluku intha issue fix agiduchuna oru separate short video kondu varenga. because other users kum helpful la irukumnga.
Try pannitu sollunga. wifi la connect la iruntha icloud ku contacts ellame upload aagumnga.
Also ippo google contacts use pannureengala or on device storage?
Phone App - Contacts Top Left corner la tap pannitu screenshot share pannunga bro.
Temporarily Both Gmail accounts disable pannunga bro. just iCloud Contacts mattum use pannunga. Because this feature works through cloud sync. so already icloud contacts la gmail la irukara contacts ellame update panniteenga na iPhone la iCloud Contacts mattum use pannumbothu features sync work aagurathula issue irukathunga.
Try pannitu sollunga bro.
Bro. Both Google accounts removed. Sync agiducha teriyala
See this Screenshot below bro. iCloud synced.
But as you can see in this Screenshot above that ‘Contacts’ is not listed here. Kindly if possible, give me a solution bro.
If iCloud contacts synced then within Phone App - Contacts we will see the list of contacts bro. also from top right corner in same page, you will see total number of contacts downloaded to your iPhone and available in iCloud Contacts. Can you share that screenshot?
Tried above suggestion bro? made contact poster working after moving all contacts to iCloud?
Yes bro. I’ve removed google accounts & now have only iCloud account synced. Still I didn’t get the desired result. Ennoda friend num call pannen bro. But Contact poster show aagala. Enna panradhu teriyala bro.
Kindly give some more time till iOS 17.3 comes out, bro. I have checked with a few of my friends here, and no one is experiencing such an issue. I couldn’t recreate the same problem from my side.
Ok bro. I’ll wait. iOS 17.3 epo release aagum? Also 1 more doubt. iMessages iCloud backup ON la vachiruken. But Messages app la pona, it shows ‘Sync Paused’ in the bottom. Idhuku enna panradhu?
