Custom Build SSD And Portable SSD
Read and write speed of the SSD is important bro. portable ssds always maintain that 1000 mbps or higher as mentioned in the specs. in custom ssd options read and write speed based on the adapter and ssd we connect could be different. check specific adapter user reviews and then go for it if you are planning to get a custom ssd type bro.
else T5, T7 type of ssds are good to consider.
