Display Line in iPhone XR
Hi bro I’m using iPhone XR.,now my mobile display showing the line is display problem or software problem.,how can I find
if its software issue then restarting iPhone will fix it bro. otherwise it could be hardware problem. should be checked with apple service center if you prefer original display replacement bro.
Thanks bro Ipo line konjam konjama marachetu varuthu bro🙏🏻
