After using a MacBook, do we need to shut it down like a Windows laptop, or can we just put it in sleep mode?
Hi, its not required to shutdown everytime after usage. I rarely shutdown when I was using my macbook and now using mac studio the same way. I just put it in sleep mode and start using it next day with apps I have kept opened. So far no issues bro. you can use the mac like an iPhone. just charge it around 10 to 20% and continue using it as you need.
You may leave the charger connected in day times whenever needed and use it. Mac uses direct power supply when you leave the charger connected, instead of battery power.
