Does iPhone Skins cause Overheating?
Hi bro is it okay to use skins on iPhone and iPad…bcoz of skins does iPhone get overheated
I have used capesindia skins and couple of my friends are using it bro. so far no such issues reported. normally I notice heat with camera app usage and sometimes with instagram while using it for longer time in mobile data for video streaming.
Other than that, skins cannot be the reason for such heating bro. you can go for it.
Okay bro thank you other than capes India skins wrap cart skins is it good bro
I havent personally tried cart skins bro. you can check any reviews for the same on amazon or other places and then buy one and see. make sure return or refund option is there before making purchase.
Also locally we can find skins in mobile selling shops too. they will fix it on the device when we buy from them. so check that option too.
