hi bro im using ios 18 public beta i decide to downgrade ios 17. when i downgrade process iTunes show couldt restore error code 11and phone was stuck apple logo and loading bar.what the solution bro
hi, I was telling the same recently in our videos that the downgrade without data loss is still not working. so we have to stay in iOS 17 stable version unless we want to experiment and report feedback to apple. expecting the fix in upcoming beta releases which will let us downgrade to stable iOS 17 release.
I will be checking today with iOS 17.6 and iOS 18 Beta 5. Will update the same whether its possible or not.
Did you take the phone out of Recovery mode and able to use now?
No bro phone still in recovery mode
that is my secondary phone so can i do with data loss is no problem.how can do brother
im from sri lanka brother. Inga repair shop la kaatina po baseband ic issue nu solraga apdii edum chances bro
you can use 3utools app if you are using windows to take the phone out of recovery mode bro. then it will boot normally.
before using 3utools try once to press and release volume up button, volume down button once, then press and hold side(power) button for few seconds. If that didnt help then use 3utools to take it our of recovery mode bro.
