Draining of battery capacity upto 2% within two months
Hi bro. I bought Iphone 14 plus on Aug 21, 2023 from USA. Right now the battery capacity has drained to 98% within two months. I have been following the same charging practice which you instructed. The drain of batter capacity is normal or will i be able to get any international warranty in the store.
hello bro, once battery reaches 80% within warranty period we can claim warranty. otherwise it will be depending on our usage. continue using the device 1% a month is average reduce and some months it wont be reduced. overall we get 80% reach in 2.5 years time.
Again measure battery health after 5 to 6 months usage bro. that will give us better idea.
Thank you bro. Incase anything unforeseen happens whether will I be getting international warranty here in india.
yes bro. last time I checked with iPlanet, it is possible to claim warranty in india for device brought from other countries. with Applecare+ also warranty claim possible.
Thankyou bro
Bro today another 1% have dropped now battery % is 97. Shall i wait and analyse for 5 to 6 months or approach service centre
Yes bro. totally 5 to 6 months once measuring will give us better idea. else within warranty period even 1 day before warranty ends you can get it checked at service center for any defects. dont worry. continue following the charging practice suggested in our video.
Bro right now the battery percentage is 95%. 5% drop in 5 and half months, whether this is normal or i need to contact service centre.
It is normal bro. dont worry. continue following the charging practice and it will be maintained. some months it wont reduce and you will reach that 2.5 years mark.
Thank you Brother :pray:t2:
Hi Bro, As mentioned earlier I purchased 14+ on Aug 21 2023. Now the battery percentage is 89% and there is a sudden drop in battery percentage from 91% to 89% within 8 days whether this is normal.
Right my phone is running on ios 16.7. Whether is recommended to update for ios 17.6.1.
hello bro, for 12 months 11% reduce is normal. continue with the charging practice. battery health must have refreshed. so you are seeing updated battery health percentage.
iOS update is totally depending on our personal choice. if there are no issues you may continue using the older version.
If you like to experience the new features and receive latest bug fixes and security fixes you may update.
iOS Update alone wont be the reason to prevent battery health reduce bro. it depends on our usage and charging practice mostly as per my understanding.
Whether can I update to latest ios is there any issues in 14+ after the updates
14 plus is 2 years only older model bro. so no problem. and no big issues reported so far. If you are ready to experience the iOS 17 features you may proceed with the update. 17.6.1 is so far stable and running good.
Bro right now it’s 87% and it’s a sudden reduction by 2% in just 3 days. Is there any troubleshooting steps or Does the case have any relation to this reduction.
The reduce in battery health is happening due to refresh bro. automatically adjusting based on months of usage. did you calculate from month of purchase and usage?
Kindly refer this video.
Bought this phone on August 2023 bro its around its around 14 months and the percentage is reduced by 13%
Thats good for 14 months usage bro. continue with the charging practice and it will be maintained over period of months usage to reach that average 2.5 years time bro.
