Robin bro
Usual aa use panre external hdd inneki connect panninen but files onnume ille bro, I’m totally upset due to this. Used space kaatudhu bro
Pls advice me what to do to get my files back.
Please It will be great if you can response bit early.
Hi bro, sad to know, but files size iruku appadina temporary issue va irukalaamnga. same drive disk utility tools mathiri windows la irukarathula repair kuduthu paarunga. disk repair tools are built inside windows OS. search in the menu at bottom left corner windows system menu search feature bro. I hope it helps.
