Hi bro ,
How are you ? Hope you are good !
Suggest a external hard disk(1TB) for long run
Hi bro ,
All good bro. thank you. Hoping you too. If you are using iPhone 15 Pro models then you may consider Samsung T5 or T7 SSD.
https://amzn.openinapp.co/jtznx
Should be good for long run.
Bro
Price is too high bro
Suggest under 5k bro !
Bro , enoda iPhone 13 wifi la connect aaga maatuthu. Connect aagi few sec la no internet connection nu varuthu but matha mobile la connect pani paatha wifi correct ahh work aaguthu. Any solution from your side ?
During offer period 6 to 7K varumnga. I dont think 1TB SSDs branded ones available around 5K range bro. 512GB mathiri paarunga. it still comes around 6K bro.
do perform āSettings - general - reset - reset network settingsā once and check bro.
Okay bro . Fine
HDD use panulam ahh bro iPhone 13 as a secondary strorage device ahh ?
Yes reset network settings tha pana . Now okay bro
HDD separate power supply iruntha use pannalaamnga. otherwise not possible to use as they draw too much power out of the device.
Okay bro understood but iPhone to laptop by snapdrop and lap to HDD bro .
Any good HDD are you using now ?
I moved to SSD bro. HDD read write speed is very slow. So SSDs are time saving. considering 1000 Mbps per second will help.
Okay bro . Thanks for your reply!
