Hi irobinpro,
Off late, Find my AirPods are not working properly. How much ever I try, I would not be able to find it. Any solution to it? Previously it used to work fine
Hi irobinpro,
Hello bro, do perform reset of airpods as adviced in this episode.
Steps are similar, so shared this episode. Also remove airpods from iPhone bluetooth settings.
Then you can add airpods fresh to your device by bringing it near to your iPhone. Then check find my feature is working or not bro. do check location services settings. whether its ON for find my services too.
