Hi Robin bro ,
I am using iphone 15 pro max latest version of software, my phone is reducing 3 to 4 % overnight drain, I know you have mentioned in many of your post it’s normal, but thing is around 12 pm to 4 am Fjnd my app is running and it’s the only thing running and showing 100%. Should I be worried?
Lastly my cycle count is
170 and battery health is 97%. I use stuff cool 20w charger , If I charge using 10w will my battery life improve in general? It’s a general question
hello bro, overnight upto 8 to 10% is normal bro. based on network conditions some time we may see increased overnight battery drain. But it will be different next day when less background processing and network usage happens.
find my updates its location at times to the server. its normal and not to worry. just make sure to run latest iOS software and there are no bugs reported with find my or other system services.
iOS 17.6.1 is stable and running very well.
Continue following the charging practice and it will be maintained bro.
Hi bro , What about my second question. I am using 20W PD charger, if I use 10W charger will I see improvement in my SOT (battery life in a day ) or like Battery health improvement (Taking more days for percentage reduction)
Reason I am asking is , I have time to charge my phone for 2 hours or more, will I get any benefits if I do this way ?
20W is what most of us using it now a days bro. no need to change adapter. iPhone controls input power at both hardware and software level. even with optimised charging feature ON, it don’t accept input power more than 20W. 15 pro max supports up to 25W so don’t worry about it. you can use 20W adapter to charge.
fast charging also managed automatically. when internal temperature increases, charging cut off automatically or slows down. this wont affect battery reduce or battery health.
it all depends on your usage and charging practice like not draining the battery frequently to zero percentage helps to maintain over period of months usage.
