Formatting Macbook Frequently can cause SSD issue?
hi robin bro, my friend software developer irukanga and class ,multiple project run panranga class edukuranga bro m3 air 15 inch 16/512gb use panranga, ipo enna doughtna mothly 2 or 3 times mac erase panra madri sutuation varudu solranga some time os install panna apple service center kudpangalam avangluku enna doughtna adikadi mac erase panra nala internal ssd issue varuma , performance issue vara chance iruka katkuranga , enaku tharyadu adan na ungalda katu solran sonna bro, ssd issue problem vara chance iruka 2years no issue konjam reply panunga bro
Hi bro, SSD porutha varaikum read and write evlo pannurom appadingrathu thaan. so monthly 2 to 3 times format pannurathu athiga read and write pannura mathiri thaanga. new model la issues eppothum varathu. namma guarantee a solla mudiyathunga issue varuma appadinu. depends on frequent usage and handling.
avora usage ku ok va iruku na use panna sollunga. work naala macOS Restore panna vendi iruku. so continue pannatum bro. no problem.
ama ji tcs work panraru time illa solraru,ssd issue performance yapdi tharinjukrathu
bro my laptop battery back up bugs fixes check panra kandi erase all content nanum inda 1yearla oru 6 times erase pani irupan 2 times service centerla os poda kuduthan 15.2 and then 26.1 idunala macbook m2 pro issue varadula bro
ios 15.7.2 use panran 26.1 update pannalama complete restore pannalama bro 16 pro max use panran konjam reply panunga bro waiting
Intha steps try pannalamnga terminal la pannanum to find SSD count.
issue vara chance very less bro.
iPhone 16 pro max la 26.1 pannalaamnga. few minor bugs iruku but manageable thaan better than 26 update bro.
ok bro very thank u ios 26.1 update panidran
Bro small dought diagnostics on line and offline both are same ? Give same result in mac
yes bro. same results for both.
