Good Quality Tempered Glass for iPhone 13
I need good quality temper glass and transparent case for my iPhone 13. I am fed up buying at offline stores. I had very bad experience at offline stores.Please suggest me some brands.Quality should be good.
it covers most of the rear side color and make only camera portion color visible bro. clear case I couldnt find within same brand, do check amazon once if you want a transparent finish.
some tempered glasses like edge to edge dont fit well with few case types. so we have to go with clear tempered glass type to leave some space around that case bezel area.
while applying make sure to fit it perfectly leaving room around that top speaker area. that will avoid audio distort issue.
So instead of changing the case try going for clear tempered glass to fix this type of issue bro.
Will this case look good on my iPhone 13 blue colour ?Also i have installed the temper glass that you have referred.It is not going well with totem silicone case which I bought 7 months ago.wearing totem silicone case with this temper glass reduces the volume of the receiver and makes listening to opposite people difficult,Disturbs music.Because temper glass cover’s the receiver from front case cover’s the receiver from top (as the case has raised lips at the sides)what shall I do bro?I am ready to change the case.The case you recommend will solve this issue?
