Google Maps doesn’t work properly
Hi Bro, I’m using iPhone 16 and when I’m using Gmaps using CarPlay sometimes it doesn’t show the root instead it just show only the navigate
hello bro, possibly a bug at software level. google maps updated to latest version and running iOS 18.1.1?
Yes my device running with latest software and OS. I do remember this is happening since I have updated to iOS 18
not many users reported same issue so far bro. can you try performing “settings - general - reset - reset location and privacy settings” once. then reinstall google maps app and enable location permissions and check. that will help.
Thanks bro👍🏻I will try and will post if it doesn’t work.
