Green dot on dynamic island - iphone14 pro
Hi brother, I’m seeing a green dot present in dynamic island. I understood that one of my app is using camera.
My observation is even when i close all the applications the dot seems to be present in the dynamic island. From notification drawer i see Whatsapp is using the camera while the remains closed in my phone. Attaching some relevant screenshots fyi, not sure what happened.
My phone runs on ios 16.3.
kindly share your thoughts. Thanks
This could be due to temporary bug bro. do try restarting the iPhone once and check. it will be fixed mostly. also apple released iOS 16.3.1 you may update and check for whatsapp app updates too.
Thankyou bro, Restarting iphone removed the green dot that was present all the time.
Its a bug, after restarting the green dot (which indicates the usage of camera) and orange dot (which indicated the usage of mic) is now proper functioning as it should be.
Good to know bro.
