Bro, İm facing this recently, particularly in safari browser i dunno you have noticed or not🤷🏻 when I type something in safari search tab and engage in the content after if i want to alter the text in search bar the cursor in that is always ending up in front of the text not at the end of the text i had typed already, this is so annoying and without even noticing few times i started typing my content and realising the cursor is in front side, this im encountering few months ago only bro, I couldn’t find a kill switch for this, can you tell me is this default else there is option to change it if so tell me how bro?
is it macbook or desktop mac systems bro?
Bro it persist in normal iphone bro
Oh, touch related issue happens with mac safari before bro. with iPhone, possibly where we tap is not being accurately detected to place the cursor. So far I couldnt find any setting that puts the cursor on the first of address bar to type when text already present.
Possible practice we can do to fix is,
- Double tap the text area to select all of them and start typing the address or text you want to enter.
- Tap once on the last text position and then start typing.
If its a bug we can see it getting fixed over upcoming updates. otherwise we may have to slightly change the selection method a bit to avoid cursor jumping to first position bro.
