Bro, ios18,2 le home and lockscreen battery drain bug fixes aahuma??
Hi bro, as you have updated recently give 3 to 4 days time, you will notice difference in battery drain.
also do you have any widgets enabled in lock screen or home screen?
No bro
Restart iPhone once and observe for two days bro. see if home and lock screen again consumes more power. let me know how much percentage it normally uses in last 24 hours.
Bro, 10% activity showing ???
using any widgets on home or lock screen bro?
No bro ,only date and time
go to settings - battery page and scroll down little bit bro. show recently used top 3 apps and take screenshot. then share it here.
even though the percentage is high, when you tap on the home and lock screen it will show app wise usage bro. so if you have clock widget or other widgets enabled, then this is normal. it didnt consume more power. above battery level graph shows normal reduce only.
Charge the iPhone when it reaches 20% and continue using it normally as you do. If there is any issue you will see fast drop in battery graph.
