Hotspot disconnect automatically
Hi Bro,
Am using Iphone 7 & 14 pro max
Am connecting hotspot from 7 to 14 promax . When phones are idle hotspot disconnect automatically.
Note :-
Already try the network reset & low data mode disable .
Thanks in advance for your kind advice.
hi bro, both devices updated to latest version of iOS? also did you perform network reset settings in both iPhones?
Good Afternoon Brother,
Thanks for your kind attention.
Bro I tried both recommendation , but the problem is still appearing.
good noon bro. do try this dns configuration after connection established and see if it helps maintaining the connection bro.
