Hotspot in iphone will reduce battery
Hi iRobin Pro,
I’m using iPhone 13 with IOS 16.5.1 and From Morning 9AM to Evening 4PM my hotspot will be in on the battery is reducing fast
Fast na naan normal ah hotspot off panitu wifi connect pannalum romba speed ah reduce aguthu nu bro
As well as my doubt whether it will reduce battery life like battery health
Expecting any tips for battery saving in next video bro
Thanks😊
hello bro, in general when we use more apps, services and with more screen ON time, then battery drains and more charges we do, battery health redeuces gradually. Overall 2.5 years aagumnga 80% reach aagurathuku. usage athigama iruntha 2 years or around varumnga.
Hotspot mathiri services use pannumbothu Modem continuous usage la thaan irukum. so heating or fast battery drain is normal. especially with 5G due to faster speed, charge fast reduce irukumnga.
you can follow the same iOS 16 battery saving tips suggested bro,
Continue following the suggested charging practice even if you are using hotpost frequently to maintain battery health bro. we cannot completely stop it from reducing it, but we can prevent fast battery health reduce.
Thanks bro :blush:
