Please tell me how to clean dust, and ear wax from air pods pro.
Hi bro, you can use the same airpods cleaning method to clean airpods pro too.
Gently press and remove the suggested Faber Castell Tack It product and it will remove the dusts from airpods case and buds too.
thank you so much I was really having this issue and you just resolved it.
