Mobile la charging port , speakers , mic , silent switch la iruka dust lam remove panurathuku yethachum nalla tool iruntha solunga bro
To clean charging port, speaker grills and mic areas, you can use this method bro
avoid doing the following things while cleaning too.
Gentle a press pannitu edunga, it will pull out most of the dusts bro.
OK bro thanks ![]()
