I need to clean my iPhone 13’s back glass,Camera,sides and front screen without scratching and damaging the finish. Tell me how to clean these.Tell me the interval between cleanups.What should I buy for cleaning the phone.
We can use gentle cleaning solutions sprayed on a piece of micro fiber or cotton cloth bro. gently wipe off few weeks once removing the case and that will be enough.
Bro Can we use this spray and cloth that you told to clean the rest of the phone such as camera,back glass,phone sides,and gap left by half temper glass?
I am asking this because these are told to be used on screens.
Yes bro. just the external surface we are going to clean and directly spraying any liquid on the iPhone is not good idea. so spray 2 or 3 times on a cloth piece. liquid should not drip from the cloth. then clean it gently and you will see the back glass surface or front getting cleaned properly. then you can use it around camera sides to clean it.
Hi bro.As you said I have purchased it .But I received other brand cleaning set instead of Lapster brand.Also the cleaning kit’s packing is not fresh looks old.Mfd is 2024/02/19 expiry date is 2027/02/18.what shall I do?
See the photos bro.
Its better to return bro. do you see return option on amazon? any other reviews on the same page that says this product works well or good?
Yes bro there is return option.I did not see the reviews bro.Shall I see the reviews and decide weather to return or not?Do you know any other good cleaning set other than this?
Correct bro. check the reviews. if the liquid is good for regular cleaning, then you can use it. Some brands may stop and seller have to find alternatives. if it does the job then no problem. if its too old stock then we may return it too claiming that its not what you have ordered.
Bro, give me other brand recommendations. because this product is not of good quality. . I also need a cleaning kit for cleaning the Laptop body, laptop screen, laptop keyboard.
Hi bro, I am using just amazon basics micro fiber cloth
also this tukzer cleaning liquid has good reviews bro. do check.
check this one
