I have few apps which is taking storage so much bro .
The caller app also taking 2gb , instagram 2gb and yt 2gb how do I clear all this ? Can you please say me
Hi bro, right now it is not possible to clear out the instagram or youtube app size. but when instagram reached more than 5GB+ storage then we have to reinstall the app. till instagram side update fixes the bugs. this ofcourse iOS 17 related bug too as per my understanding.
Most of the apps are taking more than usual storage space compared to iOS 16.
You can continue using it and this wont affect your device performance. give few weeks time and we may see this improved with upcoming updates.
Save new contact only in contact app which using consuming less storage data … if u save the num directly from call list it has consume more storage, so that’s showing 1.7gb on ur storage. And, then whenever u want to clear storage delete & reinstall the apps(instagram, youtube,facebook too)
Thank you bro
