Hi bro , how are you !
Accessibility la assistive touch on pani use pana Lock Screen la um varuthu bro
Lock Screen varama iruka Ena pananum bro ?
Kindly reply
I am good bro. thank you. hoping you too. Assistive touch on iPhone once enabled, it will appear on all screens. The best we can do is, triggering assistive touch using BackTap feature. So we can turn it off and turn it on whenever we needed it.
Settings - Accessibility - Touch - Back Tap - Assistive Touch.
Simply double tap your iPhone back side with one finger to access assistive touch. that will help bro.
Okay bro
Nega sonathu check pani paatha working fine bro
And
USB C to lightning cable suggestion panuga ,a good one
Using this cable with Apple 20w original adapter
Other cables use panura apo charging ,battery health la changes irukum ahh bro
Amazon Basics MFi lightning to USB C cable try pannalaamnga. non MFi cable use panna vendaamnga. for safety reasons.
6 feet and 3 feet cable length difference irukum bro. do check and buy then.
Okay bro
Thanks for the suggestions
Intha cable + Apple Original Adapter use panulam ahh bro ? Is it okay to use with Apple Original adapter!
yes bro. use pannalaamnga.
Okay robin bro ![]()
